Sign in
Not a member? | Forgot your Password?
Search Comp.Arch.FPGA
Search tips
Free PDF Downloads
Adam Taylor's MicroZed Chronicles
Performance driven FPGA design with an ASIC perspective
FPGAs!? Now What?
Architecture of FPGAs and CPLDs: A Tutorial
FPGA Implementation of Digital Filters
Recent Blogs on FPGARelated
I don’t often convert VHDL to Verilog but when I do ...
posted by Christopher Felton
Spline interpolation
posted by Markus Nentwig
BGA and QFP at Home 1 - A Practical Guide.
posted by Victor Yurkovsky
Introducing the VPCIe framework
posted by Fabien Le Mentec
How FPGAs work, and why you'll buy one
posted by Yossi Kreinin
Learning VHDL - Basics
posted by Enrico Garante
Yet another PWM
posted by Anton Babushkin
Two jobs
posted by Stephane Boucher
How to start in FPGA development? - Simulation software tools
posted by Nuria Orduna
An Editor for HDLs
posted by Dave Vandenbout
See Also
DSPEmbedded Systems
Comp.Arch.FPGA | So Xilinx, is XDL and related libraries an available open source interface?
There are 44 messages in this thread.
You are currently looking at messages 1 to 10.
So Xilinx, is XDL and related libraries an available open source interface? - 2006-01-26 12:39:00
So the question to Xilinx is, will Xilinx release the NDA restrictions
on XDL, and the associated library interfaces so that open source tools
can legally target ISE supported FPGAs?
It's pretty clear that most of the regulars here, just assume that XDL
and the associated libraries, are an open interface, and think it's ok
to ignore the IP restrictions in the ISE license. The legaleze says
otherwise.
So how about a clear definative legal statement about what are legal
ISE interfaces for open source development.
Re: So Xilinx, is XDL and related libraries an available open source interface? - Ed McGettigan - 2006-01-26 13:58:00
> otherwise.
I believe that it is established copyright law that SW interface
specs are not protectable elements although there appear to be
some gray areas.  This seems to be a good write up from 1997
http://www.fenwick.com/docstore/publications/IP/IP_Articles/Baystate_Holding.pdf
In any case here is the output of the XDL tool in ISE 8.1i
	unix> xdl -help
	Release 8.1i - xdl I.24
	Copyright (c) 1995-2005 Xilinx, Inc.  All rights reserved.
	Xdl is a single tool with 3 fundamental modes:
	  * Report Device Resource Information
	  * Convert NCD to XDL (ncd2xdl)
	  * Convert XDL to NCD (xdl2ncd)
	Report generates a report of the physical resources
	available for a specific part.
	Ncd2xdl reads in an NCD file and generates an ASCII XDL file.
	Xdl2ncd reads in an XDL file and generates an NCD file.
	XDL is also a fully featured Physical Design language that
	provides direct read and write access to Xilinx's proprietary
	Native Circuit Description (NCD). This access enables all
	users to write tools to address their individual FPGA
	design needs.
The XDL tool explicitly states that you are allowed to create tools
that use the output of NCD2XDL or tools that create input for XDL2NCD.
This use of course is restricted to use for Xilinx devices per the
ISE 8.1i EULA.
If you want to make a tool that writes XDL or a tool that does
a read/modify/write using XDL for Xilinx devices open source
go ahead.
We have released application notes that explain how to use XDL to
modify elements in a design. Some companies like Hier Design created
and marketed their own tools using this interface.  We liked the
Hier Design tool so much we bought the company.
I don't know what you mean by "NDA restrictions on XDL".  I can't
find any reference to a NDA documentation.
Ed
Re: So Xilinx, is XDL and related libraries an available open source interface? - Antti Lukats - 2006-01-26 14:00:00
<f...@yahoo.com> schrieb im Newsbeitrag
news:1...@g14g2000cwa.googlegroups.com...
> otherwise.
Hi mr fpga_toys,
you are constantly talking about NDA restricted XDL documents, as if you
have signed an NDA with Xilinx and received special documents under that NDA
agreement, in wich case its better for you that read those NDA agreements
(signed by you and Xilinx) over again. If you have not signed such
agreements then stop talking about NDA in this context.
As of your Question to Xilinx - do not expect an reply as it totally unclear
what you are actually asking as you have not defined that. In the form you
asked your question it would deserve a "NO" as replay from any entity that
has any understanding of legal matters. Xilinx can not say YES to your
question. Well you probably know that yourself. So what are you trying to
achive with your push?
Antti
Re: So Xilinx, is XDL and related libraries an available open source interface? - 2006-01-26 14:28:00
> some gray areas.
Software copyrights yes, but Xilinx claims a business contract license
to protect IP in the release ... that is different law, and to violate
the
license is breach of contract.
> ISE 8.1i EULA.
It is this "restricted to use for Xilinx devices" that violates every
open
source license, and which as a developer using BSD licenses that we
can not accept (nor does any other accepted open source license). Be
cause of this restriction, there is no forum where the software can be
released, as it's impossible to acertain that the recipient is also
bound
by the Xilinx license terms. Open source requires that no restrictions
be
placed on the distribution, other than governmental.
So read the EULA carefully, as the business contract language requires
that you protect the IP assets you aquire as part of the license ... as
they
are trade secret and proprietary ... not public domain, and free to
distribute.
Re: So Xilinx, is XDL and related libraries an available open source interface? - Larry Doolittle - 2006-01-26 14:29:00
>> otherwise.
The conservative assumption is that the EULA we all click when
we install ISE is a valid document, and it has NDA-like clauses.
The poster has clearly read that NDA very carefully.
If you live in a country where such agreements are non-binding,
let us know here.  Then software developers in that country can
proceed without fear -- until Xilinx stops exporting chips and
software to that country for the same reason.
It's clear to me.  Are you being willfully disingenuous?
Well, maybe some clarification should be made of the phrase
"associated library interfaces".
> In the form you
In the short run, maybe the regulars will admit that XDL can not
currently be considered an open interface.  In the long run, maybe
we can pressure Xilinx to remove NDA restrictions on information
contained in XDL data files, to permit open source code to monkey
with FPGA internals (without fear of being JHDLBits-ized).  Presumably
that means Xilinx's engineers and lawers have to have a serious
talk, since a Xilinx lawyer can hardly be expected to say "YES"
to a request he doesn't understand.
Only after this is resolved, can the regulars here go back to
telling people who want to make bitstreams with open source
software to use XDL instead.
        - Larry
Re: So Xilinx, is XDL and related libraries an available open source interface? - Antti Lukats - 2006-01-26 14:33:00
"Ed McGettigan" <e...@xilinx.com> schrieb im Newsbeitrag
news:drb64u$n...@cliff.xsj.xilinx.com...
>> otherwise.
> unix> xdl -help
> design needs.
> ISE 8.1i EULA.
> go ahead.
> Ed
Hi Ed,
I wasnt quite sure if there are actual XDL documentation under NDA
so I have replied (several replies in other treads) based on my best
knowledge, eg stating that is OK to dvelop tool that use or generate
XDL, well good to have that confirmed one more time.
My reply to mr fpga_toys original post was to his question in general
where he messes up XDL and interface and libraries and ISE and
seems to request to opensource everything that is needed to generate
bitstreams for Xilinx devices in general - at least that is how I did
understand his question, and answer to the question int that form
is defenetly no.
As extension to XDL I belive the .LL file are also 'legal' source of
information about Xilinx bitstreams so that 3rd parties can develop
software and utilities that either patch bitstreams or perform
partial reconfiguration or use readback features.
So the use of XDL and LL files is defenetly sufficent to create
different type of tools that can target Xilinx FPFA very close
to the actualy physical implementation level.
And I was and am sure that any such tools (of professional quality)
would be welcomed by Xilinx as they do provide additional
features and functionality for the users of Xilinx FPGA's.
Antti
Re: So Xilinx, is XDL and related libraries an available open source interface? - 2006-01-26 14:43:00
The format of the file is useless without also being able to specify
objects proprietary to Xilinx, and not part of the XDL format itself
The real problem, is that all the licenses do not allow open source,
and are restricted to your own development because the license
doesn't specfically grant distribution rights of derived IP.
The whole "patch bitstreams" is where you quickly get into IP outside
the XDL format.
But not open source as long as the xilinx only restriction is in place.
And certainly not on sourceforge, or other widely used public
distribution
point.
Re: So Xilinx, is XDL and related libraries an available open source interface? - Antti Lukats - 2006-01-26 14:47:00
news:1...@z14g2000cwz.googlegroups.com...
> the XDL format.
> distribution
> point.
and you mr fpga_toys are still an ..... ......
(everyone please fill in the blanks)
Antti
PS I self-censored my previous response to mr fpga_toys.
Re: So Xilinx, is XDL and related libraries an available open source interface? - Ray Andraka - 2006-01-26 15:28:00
> Antti
Antti,
Time to stop feeding the troll.  We've given Mr. FPGA_toys the
information about the hooks he needs to work within the framework of the
xilinx tools.  He's obviously not going to be happy unless they decide
to make the entire tool chain open source.  I'm not sure I understand
why he is on this crusade.
One doesn't need open source in order to read and write to the XDL
chain.  Xilinx encourages third party tools using XDL, as evidenced by
the text at the beginning of an XDL file as well as the statement here
on the news group by Ed McGettigan.
I've come to the conclusion that MrFPGA is not looking for a solution,
rather he is simply trolling.  We've offered a solution, but he
continues to use misdirection to try and poke holes in it because it
doesn't meet his desire for totally open source.
He also claims any XDL tools he creates cannot be distributed, which is
bunk.  He can't distribute Xilinx tools or IP, but he can certainly
distribute a tool that talks to the xilinx tools through a published
ascii interface that has the permission to use it printed right in every
file generated by it.
I think XDL is a very reasonable approach by Xilinx to offer hooks into
its tools without having to give away the farm.  JHDLbits, as I
understand it (not sure where MrFPGA is getting his info, I think he's
making a lot of it up), used information directly supplied by Xilinx
under NDA, and included some of that information in the distribution,
which was a violation of the NDA.  XDL is provided under an end user
license agreement, not an NDA.  Making a tool to interface to it, from
what I can see does not violate any terms of the EULA, provided you
don't include the xilinx tools with any distributions of your XDL tool.
Re: So Xilinx, is XDL and related libraries an available open source interface? - 2006-01-26 15:54:00
The point Ray, is that no one can use XDL in open source tools. The
XIlinx
license restricts all use to Xilinx only product, which specificaly
prevents
including it in a tool that supports multiple vendors. It indirectly
prevents
any public distribution of an XDL tool since you can not enforce the
license provisions.
The FpgaC team CAN NOT INCLUDE XDL in it's open source project.
The request was not to have Xilinx release sources to it's tools. The
request
is for Xilinx to relax this crippling restriction which prohibits open
source
use of XDL and the related library object documentation.
| 1 | | 3 | 4 | 5 |
