AGC on FPGA
Started by b2508 9 years ago●13 replies●latest reply 9 years ago●3213 views
Summary A developer sought advice on implementing an Automatic Gain Control (AGC) algorithm on an FPGA when processing data at every clock cycle, creating a timing bottleneck for gain calculation.
A developer sought advice on implementing an Automatic Gain Control (AGC) algorithm on an FPGA when processing data at every clock cycle, creating a timing bottleneck for gain calculation. The discussion evolved from addressing hardware latency to exploring the mathematical architectures of feedback versus feedforward loops and the benefits of log-domain processing.
The community recommended using window-based averaging and delay lines to sync data with gain calculations, ultimately suggesting log/antilog implementations to linearize the system and simplify time-constant management.
  • Compensate for processing latency by using a delay line on the primary data path while the gain is calculated in a parallel sidechain.
  • Transition from a feedback to a feedforward architecture to more easily manage high-throughput data streams.
  • Implement log/antilog conversion to transform multiplicative gain adjustments into additive offsets, simplifying the control loop.
  • Avoid instantaneous gain changes by using an integrator or low-pass filter to prevent the AGC from acting like a signal clipper.
  • Use a leaky integrator instead of a simple moving average to achieve smoother attack and decay times without excessive hardware resource consumption.
FPGADigital Signal ProcessingAGC Algorithms
Hi All,
I need to create an AGC algorithm on FPGA. I am using some basic algorithm, but I receive input signal in every clock cycle.
In AGC algorithm, in case I have sample x(1) and use it to calculate gain g(2), this gain should be applied on the next sample x(2). However, sample x(2) comes directly after x(1) and it takes multiple clock cycles before g(2) is ready.
Do you have some ideas on how to overcome this in FPGA? Is it even possible to create AGC on FPGA if data comes at every clock cycle?
Thank you very much in advance.
Reply by neirober●November 15, 2017
I think you need to read up on how digital agc is typically done.  At its simplest, digital AGC consists of a threshold detector, integrator, and multiplier.
Here is an article I found:
https://www.embedded.com/design/other/4214571/A-simple-way-to-add-AGC-to-your-communications-receiver-design-
regards,
Neil
Reply by Rick Lyons●November 15, 2017
Hi Neil.  I've never seen that web page before!  I see that the "Embedded" web site folks deleted the references I provided in that section of my DSP book.  Most of what little I know about AGC I learned from DSP guru fred harris (of "Blackman-Harris window" fame).  The references missing from that online article are:
[76] Harris, F. “T102: Digital Signal Processing for Digital Modems,” DSP World Spring Design Conf., Santa Clara, California, April 1999.
[77] Harris, F. “On the Design, Implementation, and Performance of a Microprocessor-Controlled AGC System for a Digital Receiver,” IEEE Military Communications Conf., San Diego, Caliornia, October 1988.
[78] Analog Devices, Inc. “80 MSPS, Dual-Channel WCDMA Receive Signal Processor (RSP) AD6634,” Data Sheet Rev. 0, 2002, pp. 28–34
Reply by tarikkazaz●November 15, 2017
Hi Neil,
That is really nice post. I think for anlitlog and log implementation in FPGA this would be appropriate supplementary material:
Computer Multiplication and Division Using Binary Logarithms
http://ieeexplore.ieee.org/stamp/stamp.jsp?arnumbe...
b2508 I think now you have all components of an AGC.
I suggest you to first try to implement it in Matlab/Python, then go for
HDL. Implementation of Antilog/Log can be tricky. However, if you understand paper that I have provided link on, it should not be so hard (just shifting, and taking care of signal format)
Kind Regards,
Tarik
Reply by kaz●November 15, 2017
Hi Neil,
Any chance you or Rick explaining "in baby steps for dummies" how log/antilog approach sorts out the time constant problem.
Kaz,
I am not expert on AGC.  Maybe that's something I can study and write about sometime in the future.
regards,
Neil
Reply by Tim Wescott●November 15, 2017
Ooh ooh!  I get to use "homologous" in it's natural habitat!
Because if you do the naive AGC loop, then the loop gain is proportional to the AGC gain and (if I recall correctly) the signal level.   The system isn't linear at all, but with an ACG setting that varies slowly enough it looks like a linear system with a wildly time-varying loop gain and, hence, time constant.
This SHOULD make sense if you work out the loop gains for a simple system with a constant-amplitude input.
If you do the log/antilog thing, then the AGC gain and signal strength show up as offsets (rather than multipliers).  The system is homologous* to a nicely linear system.  If you just use an integrator and a summation block (after putting your logs and antilogs in the right places) then you'll end up with a simple first-order system.
(Just a note -- the first time I designed an AGC loop was in analog; the crusty old guy I was working with said "oh, you don't want just an integrator, because it'll mess up how things sound".  "Sound?" I said.  "Oh right -- this is a data link."  So if it's for AM radio, you may want to use a leaky integrator so it sounds right.)
* I got to use it!  I got to use it!
Reply by aser●November 15, 2017
AGC usually has three units. The first one is the magnitude calculator, the second one is the low pass filter for that magnitude, and the third one is the multiplier of the signal to the inverse value of the filtered magnitude. The low pass filter is not sharp but has rather low frequency band.
Reply by b2508●November 15, 2017
Thank you to all.
I do not have an option of oversampling so I switched from feedback to feedforward solution instead and it seems ok.
I have only one issue left. I do not understand how to achieve good attack or decay time. I tried using moving average filter (with filter of length N having all coefficients equal to 1/N) but it seems that I cannot achieve averaging by much more than 400 samples with my hardware. If my data has a rate of 20kHz then this 400 samples would be very quick and not pleasant for listening if gain suddenly increased.
Does anyone know reasonable sizes of attack/decay times and how they are implemented?
Reply by borysk●November 15, 2017
unfortunately I don't have any FPGA experience but I think normally in digital signal processors you should assume some delay due to the processing time.
In that case, why not calculate your gain based on a window consisting of several samples, longer or equal to the number of clock cycles to calculate it?
Are you aiming at truly instantaneous AGC anyway? It might not sound that nice. If you use a time constant longer than the averaging window, the length of the window is not a problem any more :)
For reference, check Giannoulis et al. "Digital Dynamic Range Compressor Design— A Tutorial and Analysis", J. Audio Eng. Soc. vol. 60, No. 6 (2012). Not exactly AGC, but DRC works on very similar principles - see section 2.3 Level Detection.
Borys
Hi Hello,
I do not know how you AGC loop looks exactly. However, I am sure you can do following:
-You can split your datapath into two datapath (one for calculation of gain, and another one ( delayed for few clock cycles (delay is equal to number of clock cycles needed to calculate gain g()).
- After this you could applied your gain g() to sample X2.
Is your loop feed forward or feed backward ???
Kind Regards,
Tarik
I am not clear why AGC loop should work on sample by sample basis without any delay. Normally we check signal power over some time window, possibly then filter the error and then apply correction to incoming stream.
Reply by probbie●November 15, 2017
You should integrate your data otherwise, if the algorithm acts 'instantaneously', you will have built a clipper rather than an AGC. The integrator would be very simple, consuming little resource, and will smooth the gain changes. However, the integrator will limit the responsiveness of the system, so there would be overshoots etc. You could reduce this characteristic (it it was considered to be a problem) by putting a delay before the 'gain cell' of the AGC so that the control sidechain can 'look ahead' for any forthcoming peaks.
Probbie
Reply by jbrower●November 15, 2017
b2508 I see several good algorithm suggestions here, but assuming your current algorithm is fine as-is, do you have available a faster clock ?  Or can you synthesize one from your current sampling clock ?  For example if you use a 10x clock and sample every 10th sample, then you have 10 clocks to calculate g(2).
-Jeff
