Got syntax errors in both mainboard and uart-receiver files
Started by Jamanen 9 years ago●2 replies●latest reply 9 years ago●178 views
Summary A developer encountered numerous VHDL syntax errors while trying to instantiate a UART receiver component within a mainboard design for an Altera Cyclone V FPGA using Quartus II Lite.
A developer encountered numerous VHDL syntax errors while trying to instantiate a UART receiver component within a mainboard design for an Altera Cyclone V FPGA using Quartus II Lite. The discussion focused on potential issues with generic declarations and component instantiation based on examples from the Nandland website.
The thread concluded with the user being directed to a known-working reference project on OpenCores that successfully implements UART on Cyclone V hardware using similar generic parameters.
  • The user experienced syntax errors specifically when declaring and instantiating components with generics in VHDL.
  • The project targeted Altera Cyclone V FPGAs using the Quartus II Lite development environment.
  • A working alternative implementation from OpenCores was recommended as a reference for proper generic and baud rate configuration.
  • The user confirmed that the external reference code helped resolve their understanding of the design structure.
VHDLQuartus IIUARTFPGA Design
I want to design a UART receiver/transmitter and by now I already developed the receiver vhdl file but when declare and instantiate the the receiver component on my Mainboard Design I get very much syntax errors in both files, mainboard and uart-receiver.
The following is the mainboard design. I use generics. Could the problem be here? I already tried different approaches like setting the generics with ":" or with "=>" in the instantiation but nothing worked. It is a vhdl design for an altera FPGA (Cyclone V), I'm using Quartus II Lite. I got the design from an Internet Site (https://www.nandland.com/vhdl/modules/module-uart-serial-port-rs232.html)
LIBRARY IEEE; USE ieee.std_logic_1164.ALL; USE ieee.numeric_std.ALL;
ENTITY mainboard is PORT( CLOCK_50_B5B : IN STD_LOGIC;
        LEDG : OUT STD_LOGIC_VECTOR(7 downto 0);
        LEDR : OUT STD_LOGIC_VECTOR(7 downto 0);
        KEY : IN STD_LOGIC_VECTOR(4 downto 0);
        CPU_RESET_n : in STD_LOGIC;
        GPIO : INOUT STD_LOGIC_VECTOR(36 downto 0)
     ); END ENTITY;
ARCHITECTURE behavior of mainboard is SIGNAL LED_7 : STD_LOGIC; SIGNAL LED_6 : STD_LOGIC; SIGNAL CLK100 : STD_LOGIC; SIGNAL locked : STD_LOGIC; SIGNAL SF_D_signal : STD_LOGIC_VECTOR(3 downto 0); SIGNAL Reset : STD_LOGIC; SIGNAL RX_byte_sig : STD_LOGIC_VECTOR(7 downto 0);
component uart_rx
generic (g_CLKS_PER_BIT : integer); port (
  i_clk       : in  std_logic;
  i_rx_serial : in  std_logic;
  o_rx_dv     : out std_logic;
  o_rx_byte   : out std_logic_vector(7 downto 0)
  end component;
component Test1_Led
port ( clk_in : in STD_LOGIC;
        led_out : out STD_LOGIC); end component;
component test
port ( refclk   : in  std_logic;
        rst      : in  std_logic;
        outclk_0 : out std_logic;        -- outclk0.clk
        locked   : out std_logic); end component;
component lcd_control
port ( clk : in STD_LOGIC;
         reset : in STD_LOGIC;
         init : in STD_LOGIC;
         init_ok : out STD_LOGIC;
         row_select : in STD_LOGIC;
         Data_in : in STD_LOGIC_VECTOR(19 downto 0);
         SF_D : out STD_LOGIC_VECTOR(11 downto 8);
         LCD_E : out STD_LOGIC;
         LCD_RS : out STD_LOGIC;
         LCD_RW : out STD_LOGIC;
         SF_CE0 : out STD_LOGIC);
end component;
constant c_CLKS_PER_BIT : integer := 54;
BEGIN
lcd1 : lcd_control
port map ( clk => CLOCK_50_B5B,
              reset => Reset,
              init => '1',
              init_ok => LEDG(0),
              row_select => '0',
              LCD_RS => GPIO(35),
              LCD_RW => GPIO(33),
              LCD_E => GPIO(31),
              SF_D(11 downto 8) => SF_D_signal(3 downto 0),
              SF_CE0 => GPIO(0),
              Data_in => "00010010001101000000");
led1 : Test1_Led
port map ( clk_in => CLOCK_50_B5B,
              led_out => LED_7);
led2 : Test1_Led
port map ( clk_in => CLK100,
              led_out => LED_6);
test_inst : test
port map ( refclk => CLOCK_50_B5B,
              rst => not KEY(0),
              outclk_0 => CLK100,
              locked => locked);
uart_rx_inst : UART_RX
generic map ( g_CLKS_PER_BIT => 54) port map (i_Clk => CLOCK_50_B5B,
          i_RX_Serial => GPIO(1),
          o_RX_DV => LEDG(3),
          o_RX_Byte => RX_byte_sig);
Reset <= not CPU_RESET_n;
LEDG(7) <= LED_7;
LEDG(6) <= LED_6;
LEDG(5) <= CPU_RESET_n;
LEDG(4) <= Reset;
LEDR(7) <= GPIO(1);
GPIO(19) <= SF_D_signal(0);
GPIO(21) <= SF_D_signal(1);
GPIO(23) <= SF_D_signal(2);
GPIO(25) <= SF_D_signal(3);
LEDR(3 downto 0) <= SF_D_signal(3 downto 0);
END ARCHITECTURE;
The Uart Design File (entity) is coded like this:
library ieee; use ieee.std_logic_1164.ALL; use ieee.numeric_std.all;
entity UART_RX is
 generic (g_CLKS_PER_BIT : integer := 54);
 port ( i_Clk       : in  std_logic;
       i_RX_Serial : in  std_logic;
       o_RX_DV     : out std_logic;
       o_RX_Byte   : out std_logic_vector(7 downto 0)); end UART_RX; ...
I got the following errors:
    Error (10500): VHDL syntax error at mainboard.vhd(96) near text "Â"; expecting >";", or "port", or "generic"
    Error (10500): VHDL syntax error at mainboard.vhd(97) near text "port"; >expecting "<="
    Error (10500): VHDL syntax error at mainboard.vhd(98) near text "Â"; expecting >"!", or "=>"
    Error (10500): VHDL syntax error at mainboard.vhd(99) near text "Â"; expecting >"!", or "=>"
    Error (10437): VHDL Association List error at mainboard.vhd(98): positional >associations must be listed before named associations
    Error (10500): VHDL syntax error at mainboard.vhd(100) near text ";"; >expecting "<="
And in uart file:
    Error (10500): VHDL syntax error at UART_RX.vhd(5) near text "Â"; expecting >"entity", or "architecture", or "use", or "library", or "package", or >"configuration"
    Error (10500): VHDL syntax error at UART_RX.vhd(7) near text "Â"; expecting >"end", or "begin", or a declaration statement Error (10523): Ignored construct UART_RX at UART_RX.vhd(6) due to previous >errors
    Error (10500): VHDL syntax error at UART_RX.vhd(15) near text "Â"; expecting >"entity", or "architecture", or "use", or "library", or "package", or >"configuration"
    Error (10500): VHDL syntax error at UART_RX.vhd(18) near text "Â"; expecting >"begin", or a declaration statement
    Error (10500): VHDL syntax error at UART_RX.vhd(20) near text "Â"; expecting >")", or "," Error (10500): VHDL syntax error at UART_RX.vhd(21) near text "Â"; expecting >"begin", or a declaration statement
Can you help me finding the mistake?
Reply by MixedSignal●November 27, 2017
Hi Jamanen,
  Perhaps this example code at  https://opencores.org/project,simple_uart_for_fpga  can help. It is a UART that I have compiled successfully onto a Cyclone V FPGA. It also uses generics to declare clock frequency, baud rate and parity.
Reply by Jamanen●November 27, 2017
Hi!Thanks for your help. I'll take the code for reference.It really helps!
